how to time 2.4 in 03 camry
4 reading
1K views 1 reply 2 participants last post by  apsbainc
I have a 03 camry I am changing the crank in it how do I change the gear off stock crank. And put it all back in time can some one tell me
Easy... before you pull the current gear off, use a dremel/grease pen or something to make a small mark on the shaft and on the old gear to indicate its correct orientation. Then when you put the new gear on, line it up with the mark you made while comparing the old gear to the new in its relative orientation to the shaft.
