5SFE Distributors
1 reading
5.4K views 9 replies 4 participants last post by  myname
I've become curious about the types of distributors offered on the 5SFE.
Looking at the FSM and also the Haynes book, one can see that there are two types, external and internal coil. Both also show a slot for timing adjustment where the hold down bolt is located.
Here's where it get a bit confusing, for me at least, the distributor on my 96 2.2 5SFE does not physically resemble that which is shown in the manuals. It does not have a slot where the hold down bolt is located.
Dug around a little, after getting the PN off the distributor.
Here it seems to be saying there are four different types available for the motor: http://toyota-usa.epc-data.com/camry/sxv10l/1721/engine/1902/19100/
One is the Cali spec so that is understandable I guess, but I'm left wondering why the three others?
19100-74230 is what is on the vehicle. Anyone tell me how to decipher the part nos.? Maybe that would help me understand why there are 4 dist available for the motor.
Thanks, sometimes figuring out the right question to ask is the most difficult part of things.
From your post I was led to this: http://www.toyotanation.com/forum/1...3-3rd-4th-generation-1992-1996-1997-2001/415015-need-5sfe-3sfe-engine-guru.html
"Any pre 1995 engine is going to be OBD1 so thats guaranteed to have a different wiring harness than an OBD2 motor. The 5S-FE became the standard 4-banger for the camry in 1992. This was the second generation of the motor however, since they put the first gen in the celica starting in 1990. Once you get to the OBD2 threshold, 1995 and up, there will be external coil distributors and coil packs to throw on the mix. 1992 -1995 has internal coil distributor. The 1996 has an external coil distributor. 1997-2001 has a distributor-less ignition with twin coil packs. Crank and cam position sensors were also added in 1997"
#5 · (Edited)
I don't want to confuse people, but I have a 1996, and it has a crank position sensor AND a camshaft position sensor, the latter which is located inside the distributor...although this camshaft sensor is very "primitive" and part of the distributor. Also, whether the ignition coil is internal/external seems to depend whether or not the car is for California or Federal emissions (just like how some parts/compatibility is specific for cali/federal emissions). This business about external/internal ignition coils is talked about in Haynes as well as the FSM...also suggesting a link between Cali/Federal emission....
While at the dealer this am getting some ATF for the Highlander a chance meeting with a seemingly knowledgeable and helpful Asst Parts Mgr gave me some ideas.
First, the reason I'm doing all this is due to a vibration at idle after a timing belt replacement.
So, the parts guy says the motor may still be running on logic stored over time in the computer. He further stated that this logic may cause issues due to operating on the previously stored logic and since the timing belt has been replaced.
He went on to suggest that doing a reset of the computer by means of diagnostic could result in problems going away.
In a way, what he was saying made sense to me but, as always with dealer situations, they are trying to generate sales. Therefore I'm cautious about heeding his advice.
#9 ·
I doubt it. But it won't hurt anything to try. Pull and reseat the EFI fuse in the box under the hood, rearward of the battery. That'll clear the ECU back to default settings for everything. Sorta like rebooting a PC.
Sent from AutoGuide.com App
Reactions: myname
Hmmm, re-seating of EFI fuse caused an initial drop of idle down to about 650 or so. No other effects were detectable.
This'll probably have to be left hanging. Got a state exam coming up to review for.
Plus it'd likely be better to get the planned tuneup out of the way first and maybe the idle problem might get corrected from doing that.
